Color 64 BBS v8.1a
The unofficial update that became a full-scale overhaul
Version 8.1a is live. This isn’t a patch. It’s a renovation with the lights on and the soldering iron still warm.
Support is standing by right here on the forum. If something flickers, I’m on it.
What 8.1a Fixes from 8.1
- Networking restored
- Sysop Chat restored
- Editor and DIR Tools restored
- XXX MSG fully reprogrammed for 8.1 format
New Features Added
Email Notification System
Requires Python3 on a separate networked machine. Script included. -
SYSOP In/Out flag and notification
Additional screens
- Welcome
- Wall
- Sysop In/Out
- User email notification
New Games Area using AUX3 with dedicated menu
User Self-Service Profile Editor
- Email signature
- User splash screen
- Profile details
DOS Wedge Help Menu
Fast Logon from Local Console
AutoSignature in Message Editor
Graffiti Wall
Random “Sayings” at logon before first prompt
Additional overlay routines
Sysop remote upload to any drive including Program, System, or REU
Documentation
- Online Manual: https://www.color64wiki.itchybutt.org/
- Hard Copy Manual (PDF): https://www.color64wiki.itchybutt.org/images/d/d3/Color_64_v8.10a_Sysop_User_Manual_.pdf
- Technical Support: this forum
Register on this website to receive announcements for critical fixes and updates.
Updated Build as of Feb 11, 2026 (includes Feb 06 notes)
- Corrected multi-transfer routines
- Full audit across LTK, Windows, Linux, D64, D81, and SD2IEC media
- Removed LTK-specific code from D64, D81, and SD2IEC builds
- Corrected Punter download issue
- Improved Linux build scripting and install documentation
- Fixed +EDITOR copy error
Installation File Download Options
Full Package
Includes D64 + D81 media, documentation, and useful tools. -
LTK (for VICE use)
- Windows LTK
Includes a modified VICE build (ACIA fix for high baud rates) + scripts for BBS operation. - Linux LTK
Includes a VICE installer (includes ACIA fix) + scripts for BBS operation. - LTK Disk Images Only
For systems that already have the modified VICE version running LTK.
- Windows LTK
SD2IEC Build
For Commodore hardware with an SD2IEC drive. Includes a 4GB SD card image to burn using tools like Etcher.
(Download file size: 273MB) -
D64 Files or D81 File
Contains the files necessary for the BBS. Ideal for sysops upgrading an existing system or building on existing hardware/media.
Downloads
- Main download section: Open page
- Full package (Traditional Build): Download ZIP
- Windows LTK build: Download ZIP
- Linux LTK build: Download ZIP
- LTK disk images only: Download ZIP
- SD2IEC 4GB card image (273MB): Download Zip
- D64 images: Download ZIP
- D81 image: Download ZIP
Update History
Changes incorporated since April release
April 2025
- Correction to networking program errors; minor sysop manual corrections
- Bug squashed in stand-alone editor (line delete function wasn’t working fully)
- Bug found in BBS.XFER at line 6315 that caused FILE NOT FOUND
May 2025
- BBS.MSGS held extra space due to how it was saved. Corrected.
27 July 2025
- Added +bbs file to the D64 formatted “Traditional Build”
- Cleaned up/corrected menus and help files
- Minor code corrections (removed my specific BBS info; one minor change in BBS.OV3)
- Updated user manual with minor corrections
07 August 2025
- Several corrections in BBS.INIT, BBS.MSGS, BBS.XFER, BBS.GAMES, network files, and install disk games
- UI facelift for network setup
25 August 2025
- Critical update to SYS.NET (for BBS Network capability)
- All distributions in the original post updated to 25Aug or newer
15 Sept 2025
- Minor updates to bbs.nw1, bbs.nw2
- Corrected missing file in LTK build (bbs.msgs)
- Minor facelift to bbs.ovl, bbs.xfer, bbs.msgs (Sysop temporary user edit / F5)
- Updated files affected disks 1 and 2 of the D64 images
17 Sept 2025
- Corrected issue in bbs.profile (signature or welcome banner not saving)
- Edited “Traditional Build” files where Linux filename translation caused “A” prefixes when moved to disk/images
- Fixed sys.edit copier option “X” causing syntax error
- Rebuilt SD2IEC distribution as a full SD card image made on real hardware (to avoid filename corruption)
23 Sept 2025
- Bug in BBS.XFER prohibited blocks-free on non-LTK systems (D64 + Traditional Build only)
30 Sept 2025
- Bug squashed in LTK builds causing ILLEGAL FILENAME error
25 Oct 2025
- Incorporated lessons learned for alternate Linux platforms (LTK build)
- Added Windows LTK build
31 Oct 2025
- Added VICE packaging to LTK builds
08 Nov 2025
- Squashed LTK build syntax error (bbs.init line 12456)
31 Jan 2026
- Corrected BBS Punter downloads
- Improved Linux scripting
- Auto-signature error avoidance
06 Feb 2026
- More corrections in bbs.ovl for multi-transfer
- One bug found in sys.edit causing a syntax error
11 Feb 2026
- Conducted audit across all images and removed LTK-specific bleed-over into D64, D81, SD2IEC
- Corrected additional multi-transfer issues in bbs.ovl
- Misc code cleanup
- Updated SD2IEC image to current code maturity
This build represents steady maturation across media types, platforms, and environments.
If you are running Color 64, this is the most complete and stable 8.x release to date.
See you on the boards. ![]()
